- Joined
- Oct 6, 2006
- Messages
- 117,387
By a 19-in pad, moron16” driver with an 18” deck.
WTF
VLM is where I dominate you. Did it for several years and mastered it. It doesn’t matter how big the pad is, you need head weight on that pad to actually clean.By a 19-in pad, moron
WTF
If there’s no head weight on the pad, you might as well just clean the carpet by hand.
You’re diverting.Let me point out you had the best carpet cleaning while I never made in your hands and you were too green to realize it...
Same goes with the Trinity spider which I considered to be the second best OP machine on the market and yet you were too green to realize it
You're still in that silver bullet hunting stage of your young career, try to be a little more patient and rely on tact to do most of the work for you
How many different pre-sprays do you have in your garage right now?
You’re a rookie with VLM.Several years big woop.
20 plus for me![]()
You’re diverting.
The pad driver should match the deck plate.
Period
You still think MF pads hold a good amount of soil.
They don’t....
cotton pads hold at least twice as much.
do a test on the same room and then see.
You’re just wrong.Cotton blend pads load up with soil so quick you'd have to change them out every 20 or so square feet on normally soiled commercial glue down.
Microfibers will hold more and stay cleaner on the surface so You don't have to change them out constantly.
You've obviously mastered nothing but confusing yourself..
Do the math...So you really want to oscillating deck plate banging into the baseboards?
And I'm the rookie.....
Yes, one must use more cotton pads per SF, but at least they extract dirt.
Gotta disagree here. I've tested both on the worst of the worst and the micro fibers kick ass.You still think MF pads hold a good amount of soil.
They don’t....
You’ve tested?Gotta disagree here. I've tested both on the worst of the worst and the micro fibers kick ass.
Yup.. I have spokenYou’ve confirmed.
I call BS.Yup.. I have spoken
Right, but a 2” difference?Like Mikey said I’ve done op for almost 12yrs. Pad driver can’t be same as deck due to the oscillation. It would kick out past the drive plate and smack things. I know because you can put on a larger pad driver. Which I did on a old challenger op.
Again 12 yrs into it. Mf pads rock. I’ve used a lot of different pads through the yearsI call BS.
Yea the only base that’s sits almost flush with a wall is cove base. Which sits taller than the drive plate any way.Right, but a 2” difference?
Stop using the MF rags from the auto parts store.I call BS.
