Where to find a vac motor
M
Mardie
Being from Canada our most common source of power is the 15amp circuit. Seems all the powerfull vac units have 2 cords 1 for a 15 amp circuit and the other for a 20 amp circuit which i cannot use. So i was wondering if i could run 2-15 amp lines into a converter to run the vac motors ?
Will this allow me to get bigger and more powerfull motors than 2 seperate 15amp lines.If so where can i buy the motors for this set up ?
M
Mardie
Willy you are probally the most knowledgable person on this board on how to get the most suck out of 2 15amp circuits.
Sure would be nice if you would chime in on this one.
Mytee has a converter, 2 -15s convert to 220. Not sure if there are many 220 vac motors out there. Talk to John or one of the guys at Mytee
Reactions: Mardie
Willy P
Willy P
Mytee flood hog runs on 2 15 amp circuits I believe and John does "Canadian" packages as well.Try Larry Cobb as well. My personal favourite way would be 4 - 2 stages set up 2 sets in series to a parallel. One of each set can be a high performance as well and stay within the 15 amp limit.
Reactions: Mardie
