What is an aero tech like daily
Mr Brightside
Jay Wags
Would someone notice the vacuum strength difference with an Aero tech compared to the big slide ins (870— Everest)?
would it be a game changing difference I. Anyway over these machines?
I like the rolling billboard idea of the truck and I heard they are extremely reliable
what’s the life expectancy of the XT units?
I'll tell you what. When this van shortage shit is over with I'll let you know. I'm planning on getting a DDS when I can.
Reactions: LCCFL
If you are dual wanding 60% or more of the time, go for it
If you are a multi service provider and need all the extra room but only single wand, have AT build up a rig, minus the TM and place a slide in in it's place. You can do this with a gas option as well.
Oil changes, brake jobs, tires.. everything is considerably more expensive than a van
Damon likes living on the edge
And we love his continuing disaster stories
This
I have never agreed with this but I will admit you have more experience so maybe I’m wrong but I always notice a difference with the bite
Find a tm that has a 45blower being powered by a 3or4 cylinder engine and you’ll see a difference
If it has a lawnmower engine, you won’t be able to tell a difference
Hack Attack
the blower doesnt care how many cylinders are driving it
how much horsepower, as long as its enough
2 stroke or 4 stroke
rpm is rpm
rpm is rpm
While this is true it requires around 14hp to run a 45 blower maxxed out (spec)..........and that is "electric"
add in driveline losses, ICE losses (curve) especially on mid-HP engines, and the pump and the blower might start to care because the HP isn't actually available at the blower .........unless it is underdriven
Hack Attack
add in driveline losses, ICE losses (curve) especially on mid-HP engines, and the pump and the blower might start to care .........unless it is underdriven
yep, mine starts to care on flood extractions
Im set at 16" vac relief and 100ft of hose on a flood it gets to 16"
*20hp kohler starts to bog just before vac relief
Reactions: FB19087
Mr Brightside
Jay Wags
Well I will tell you that the Everest 650hp or 870 I have suck a lot harder at any length then my old 45 blower even as much as I love my direct drives they are still not the same
100 ft of hose, same everything but the machine, how much deeper cleaning and faster drying is a #6 over a #4 blower?
rpm is rpm
Put prochem performer next to a legend SE and you'll notice a difference. I think they have the same blower.
When the hose is full of water on 200' + from steady wanding, that's the difference. How fast that water is recovered
The RPM will slow down when under full load on the smaller engines. I've seen it on several different size machines. From a little Legend and 370 to my current 650hp and Thermal wave
Reactions: Samuel
More is more, as JarhED pointed out, so obviously they're "not the same"
BUTT....since you've had and run both, you should be able to answer if there's any "practical" difference in efficiency, efficacy and dry times that makes it worth the additional costs and body wear of a "harder sucking" mega mount
Reactions: Trip Moses
Trip Moses
IMOL
Trip Moses
Practically. Under a full load. More is More.
