Rx-20 rotary union
Walt
The brass fitting on the top of the gear box - the rotary union - started squirting water suddenly. Is it possible to repair this or do I just have to replace it?
yes it can be rebuilt....the plunger on the inside or the o-rings have worn out...
it is also possible that something got stuck up in it and you may be able to pull it apart and clean it out
U
uzacarpetcleaning91
were can i get those parts from because my machine is doing the same?
boazcan
Not to hijack - but my RX is leaking at the jets. Assuming it is in the handle/trigger. What would be the easiest fix for this?
1-425-775-7276..
that is the number for the parts department..give them a call and they should have what you need......
you will need the valve rebuild kit.....
