- Joined
- Oct 7, 2006
- Messages
- 10,877
- Name
- Jim Martin
On mine...( 2004..6008 ) the lower E-3 was wrapped in isolation and had a plastic cover sealed around it to help hold the heat...but it did not allow it to breath and in time it started to rust....The out side bracket rusted and snapped off and it bounced on the frame and in time it started throwing out therm oil every time I started it up...
This is easy to change..just drain all the therm oil out and disconnect all the hoses...there is only 2 brackets that hold it on the truck and the tail piece that goes down to the exhaust diverter
The new E-3 comes with a heat shield cover that allows it to breath more but still helps holds in the heat
Slide it back under the truck and hook the 2 brackets back up and all the hoses and refill..
The gasket that goes between the goes between the tail piece and the E-3 breaks easy so you have to be extremely careful when you put it into place...
I would also recommend that if you have the hard plastic cover with the isolation around your lower E-3
to cut it off and get the heat shield wrap for it before it rust out...
