- Joined
- Oct 6, 2006
- Messages
- 117,390
Figuring out how to post that (great) picture probably took equal effort.
Thanks!!!
Thanks!!!
Thanks for the compliment. Nah; my "Petticoat Boss" has a combination Plumber, Electrician, Carpenter, Mechanic, Yard-Man, etc., etc., that hangs around that she assigns these "Honey-Do" projects to. LOLI'm not reading all that. But It looks good. I assume you hired a guy.![]()
Amen to that. Guess I could of done it a little faster; but didn't want to crowd that cheap little sander too hard, or make a mistake by rushing it. I have always been pretty patient doing things, because I want things done right; kind of a perfectipnist I guess. My Dad used to say "If you don't have time to do it right the first time; where are you going to find the time to do it over?" Have been retired a couple of years now, so have lots of time; and about the only time I do get in a hurry is heading to the supper table. LOLJust goes to show there is always another way of doing things. You got killed in time, but you learned something. Good for you
You'd make a great carpet cleaner.Amen to that. Guess I could of done it a little faster; but didn't want to crowd that cheap little sander too hard, or make a mistake by rushing it. I have always been pretty patient doing things, because I want things done right; kind of a perfectipnist I guess. My Dad used to say "If you don't have time to do it right the first time; where are you going to find the time to do it over?" Have been retired a couple of years now, so have lots of time; and about the only time I do get in a hurry is heading to the supper table. LOL
Thanks for the reply and info. I imagine imagine your sander recommendation probably would have speeded things up some. Our local H/F store is fairly small and there are some models they don't carry, and others were not in stock. The only thing I saw in the cheap, "use-one-time-and-throw-away" range was the little "Drill Master" rectangular "1/4 sheet" orbital sander. I have mostly heard only very bad reports on their power tools. I really expected it do die from extended use, and the rock dust entering and eroding working parts. It ran for a total of about 5-1/2 hours stopping only long enough to change sandpaper. Never felt it getting hot, or smelled anything unusual. I was totally surprised and impressed; especially since it was only a little over $11.00 with their coupon. The only negative I saw was that the base was not perfectly flat and the paper was not making contact except mostly around the edges. Had to shim it and then it was working fine.If it's the 5" round finish sander, I have one
as well as DeWalt, Ryobi and Makita
That cheap HF sander ain't bad at all believe it or not
wish I would saw this earlier
here's the sanding disks you want
available in grits from 80 to 2500.
'bout 20 bukz box of 50
