Oh Christ Almighty, not again...
Meter Maid
The Undetective
Dayton,Ohio
No, the Escape is that ETM unit they’ve been selling for years. This new thing is just a bigger version with twice the motors.
Look, if it ends up producing 400 CFM and 200 degree heat from Butler-like HX, I’ll look at it. It’s supposed to be around 15K with the Aurora generator and HX.
Meter Maid
The Undetective
Dayton,Ohio
what is different about it this time?
4 motors (400 CFM and 200” of lift)
Aurora generator powered by the truck. Google those generators... they’re used by our military.
A heat exchanger that looks identical to every other direct drive TM.
Being electric doesn’t seem like their selling point.
Being only 15k total and competing with 570s without any maintenance seems like what they’re selling.
Do you all hear complaints about Mytee extractors? The Escape has been out for years and I don’t really really hear anything negative. They are basically just making an Escape with 4 motors instead of 2.
The Aurora generator looks top-notch (going off internet info) and isn’t built by Mytee. The HX looks to be just like what is found on Butlers and other direct drive units. The HX also isn’t built by Mytee.
I hope it’s a success because truckmounts are ridiculously priced.
Dude...it's got electric vacs and shittons of plastic components
there are no electric vacs comparable to positive displacement blowers
count the beans ..
It's $5000 porty in a $28K van with $5000 in an aftermarket alternator and wiring
and a 200HP van engine that has to run to power and make hot water for a $5000 PLASTIC porty
it's the definition of stoopit when a $12-15K gas TM like a Judstone or TCS will suck that plastic POS into the waste tank
This was out in 2012
Meter Maid
The Undetective
Dayton,Ohio
count the beans ..
Have you seen this machine?
By the way, can you finally explain why positive displacement blowers are better? I keep hearing that, but have never heard an intelligent explanation.
Papa John
Lifetime Supportive Member
San Francisco, CA.
John Stewart
so now you're back to a porty in a van right?
unless you run a lot of cords
That Logic, is why I"m keeping my money safely in my wallet. :lol:
but environmentalists aren't always logical.
sometimes the urge to do something about global warming can be overwhelming.
Hack Attack
further south than you
2nd time this year I've had to run 200ft off my lil 36 blower, which makes it feel like a porty.. until you try the porty
I would like to try the newer Lx vacs or whatever they're called, or hear an unbiased review.. but I'm on the wrong forum 🤔
Reactions: Shorty
Meter Maid
The Undetective
Dayton,Ohio
Me too. I only come here for entertainment now.
Meter Maid
The Undetective
Dayton,Ohio
I've had the 4 vac model model for about 4 years now. i think the newer version uses the bigger 2 vac system.
but Larry is correct-- PD blowers are better.
and Yes-- there were problems right on of the box.
You have the first generation Escape that had 4 of the old, smaller motors.
Then the second generation came out with the LX motors, that were far more powerful the the 4 smaller motors that you have.
This new unit has 4 of the LX (newer) motors.
This new unit is not you unit...
  • Wow
Reactions: Papa John
so easy, even a cop can understand....
electric vacs have blow-by
meaning, if you cap off the vac port, the fan spins but no air moves
PD blowers have virtually no blow-by
cap the vac port and without a vac relief valve it will stall the engine or collapse the waste tank
that blow-by is why most of the numbers touted by porty salesmen are little more than foo-foo fluff
longevity/life expectancy ...
you'll need to replace 10 electric vacs before you'll need to replace a PD blower
if a GAS engine is needed to run a unit, that GAS engine is best used to turn a pump and PD blower .
NOT provide electricty to power a POS plastic porty
it ain't rocket science Pard'er
It's plain ole common sense
For christ sakes even their cool wand handle slips on a 1.5 regardless of how tight you crank on the bolts
and what moron puts the bolt heads on the outside?
I'm telling you FDA, I've been around since not a soul here knew of Mytee, the Greenie hyping years and their incredible downfall when the Trex virtually fell apart at a Mikey's Fest, despite BIG public announcements that HydraMaster, Sapphire and Rotovac should stop production of their RE's because the Barney was just that awesome.
It was then I ran Mighty John off MB
how about the QC covers that fall off in a strong wind or the Cufflinx version 9.8 that still are pure shit or the pool filters that cave in under 45 blower suction or the Bentley manifolds that still bust off 7 years later or...
Cheap 5th world crap.
Latest Auctions
