- Joined
- Feb 23, 2008
- Messages
- 604
- Name
- Bill Morgan
Moving company dropped a couch during delivery. Very light soil, barely noticeable, but client wants it cleaned because it cost $3500 to special order. Spoke to designer and she said it's 90% Cotton 10% Rayon with teflon protector, cleaning code S which is solvent or Dry Cleaning. I don't have a dry cleaning machine...
I've been told that 80% of "dry clean only" pieces can be wet cleaned with no problems. I've got Steam Way fine fabric upholstery cleaner for Cotton & Wool. I only need to clean the side of the arm rest and part of the bottom corner by the leg.
Could I, should I wet clean this piece?
If so, should I clean the entire armrest, side panel so that it will be uniform to reduce and risk of leaving a water ring?
If wet cleaning is not advised, would foam be acceptible? or should I tell them to find someone who can do dry cleaning?
Thanks
Thanks
just solvent and white towels..
