- Joined
- Oct 6, 2006
- Messages
- 117,387
For now...I’m in-shape, pushing a 2 inch wand with the glide is a piece of cake.
As long as he doesnt use it as a stair tool.For now...
I’m actually in my 40s, I’ve just taken care of myself. But you’re probably right, or year from now I’ll probably be buying that sapphire or the smaller Devastator again.He's a millennial carpet cleaner I guarantee you he's never used the real wand without a glide such as the Pro Kim Titanium which will do permanent shoulder damage in about 6 months of regular use especially if you're Coit chimp
The 8ft whip hose is a gawdsend.I’m actually in my 40s, I’ve just taken care of myself. But you’re probably right, or year from now I’ll probably be buying that sapphire or the smaller Devastator again.
have you ever tried that tapered hose?The 8ft whip hose is a gawdsend.
Yeshave you ever tried that tapered hose?
Few days or so.How long has it been since I’ve called you an idiot?
Whip hoses.
When I had the 12” Devastator, there was a huge difference with/without the whip. You could hear the difference.
It’s more about being able to use higher flow, I just get better results with 8 to 10 flow and I can’t pull it off with an inch and a half wand.Don't **** up your body so that your customers carpets dry 8 minutes faster..
The two times I went to a 1.5 inch wand, I got poor results. There are plenty of people who will not move away from a 2 inch wand, they can’t all be wrong.You're talking to the guy that used to run 12 flow off of a Vortex.
Chris have you yet to meet any carpet cleaners in person?The two times I went to a 1.5 inch wand, I got poor results. There are plenty of people who will not move away from a 2 inch wand, they can’t all be wrong.
I'm thinking for my moderate heat machines, it might not be so bad. I have a single wall black 2 inch hose that I use as a whip for my 2 inch tools. Hasn't collapsed yet. I'm running 190-210F at the trucks.Yes
it's wonderful up untill the point it collapses and keeps kinking over and over in the same spot
Not really.Chris have you yet to meet any carpet cleaners in person?
But he's only got a Boxer 318 I believe. Can you really run a 8 flow on that and have any heat?He’s actually correct. There is a slight difference in 6 flow cleaning vs 8 flow.
But not enough for me to wrestle the anaconda.
Wrong. I run at full blast and get a pretty consistent 180 to 190 at the wand even with my 10 flow Bentley.
Because I’m a likable idiotBoxer 318 ... I don’t know why we’re even talking to you.
Your trying to make that machine doing things it's not capable of. For one, you don't have enough vacuum to properly dry the carpets using that kind of flow. You will max out at 6 flow. If you're having problems with wicking, you are leaving the carpets too wet.With the six flow evolution, I had to crank up the psi to get decent heat and that wasn’t good.
At eight or 10 flow, I run around 400 psi and get plenty of heat for that kind of flu.
No wicking issues until I started using a 1.5 inch wand.Your trying to make that machine doing things it's not capable of. For one, you don't have enough vacuum to properly dry the carpets using that kind of flow. You will max out at 6 flow. If you're having problems with wicking, you are leaving the carpets too wet.
