Xactimate question: water extraction
RestoGirl
PA
RestoGirl
Billing for water extraction using Xactimate: we removed 3 inches of water from a 10' x 15' area, hard surface.
Is there a way to bill for the cubic area as opposed to just the SF?
You can try but they may fight it.
The reason being if it were truly 3 inches of standing water, a $100.00 submersible pump will pump thousands of gallons an hour. TM'S only make sense when a submersible or trash pump can no longer pump the water.
You could also charge hourly for the labor and the machine.
Reactions: RestoGirl
RestoGirl
PA
RestoGirl
That's what I'm thinking, I'll charge for the labor instead using the WTR EXTH code I'd usually use.
kmdineen
Redding, CT
Kevin Dineen
Square feet x Height of water (in inches) / 12 inches x 7.48 = gallons of water in structure.
150 x 3 inches / 12 = 37.5 x 7.48 = 280.5 gallons.
I think 0.25 cents per gallon was the going rate to pump out water.
Latest Auctions
