What's this system worth?
Jesse
98 Butler with 210gallon waste tank, 110 Fresh, 1 electric vac reel,1 manual vac reel, 1100hrs, 2 coolant hx. In a 98 e-350 14ft box, 25,000miles perfect condition.
Thanks
NOT MUCH.....send me the contact info. Please! :icon_razz:
I paid $46,000.00 for a used Butler in a box, it was 3-years old low hours, low miles.
dealtimeman
Everyday is Saturday.
Michael
Richard I think you have a bigger buying problem than me.
Well, we both know that's not possible! :razz:
This was years ago when the goose was still alive. :biggrin:
Zee
Thanks
Are you sure its 25000 miles? On a 98?
I have a van I bought in 08 and I'm at 89000mile right now... I would look into service records to make sure it was not spun backwords....
I have 60,000 on my pickup and I'm turning it in next week one it's 62 month.
Zee
Look at the steering wheel to see how worn out it is...is it really shiny? Is it a bit grainy (in a way when its starting to break down)?
How are the pedals? Mainly the brake pedal will show wear closer to the lower corner on the gas pedal side.
How are the buttons/switches? Are the white markings coming off? (Power windows switches will show a lot of "rub off" effect)
These are the first things to look at.....the speedometers can be turned back to showing whatever number you want for cheap....its more expensive to replace a worn brake pedal or steering wheel.
[h=2]What's this system worth?[/h]Butler with 11K hours
98 van with 25K mile?? on a new engine install????
if this is one of yours, put it out there at $8000 if it's that clean
if not yours...make him an offer of $3000
..l.T.A.
C
carpetcleaner
I don't know what it is worth. If the miles/hours are correct, expect a lot of leaks and little problems if it gets put into normal use. I used to be a Mercedes mechanic. We had a lot of customers that would buy an older, very low mileage, all original car that spent most of its life hidden in a garage. They would start driving 12,000 miles per year. Nothing but lots of things constantly going bad for a year or two.
Jesse
This is a 2nd tm for an older owner operator who's winding down, used for floods. He's got a butler in a standard length chevy for daily use. Miles are 25k for certain, hours are 1100 no doubt at all. It's been in the shade, Everything looks like new or like it's about a year old.
