- Joined
- Oct 6, 2006
- Messages
- 117,348
Im also very surprised Cobb didnt have David rule this out as its a common failure.
Have had three crack on me over the years
Last time I took my machine on for service at the local supplier(2006) I paid like $600 for a $10 diode.. At that point I new I had to dig in and learn all I can about how my truckmount worked,or get used to paying alot for service. Another thing I chose to do is stay with the same manufacturer
when you were with david did you want to test and/or rplace the ball valve or chem injector??? if it was me and you told me it could be those things i wouldnt have let you leave until we replaced those parts. and then run the tm and see if the pump worked. it seems that this was not done.
Its somewhere in all the brass fittings around the water tank and water box. Thing is there are about 15 different pieces. I can pull water from the pump if I take the water inlet hose that goes to the pump off and stick it in a bucket of water but it wont pull water from the water box or tank.
david could get the pump to prime before you got there. but it didn't stay primed. Cobb had told him that it was a bad brass. not trying to be a jerk but not staying primed was a symptom of the real problem not the problem itself. if it was me i would have said to you, "thanks for getting it to work for now but have you solved the problem or just got rid of the symptoms?" If you replied I think some brass is bad then I would have said lets make a list and start changing them one at a time.
fred you drove so far to help him it is a shame that you two couldn't have changed some of the brass parts that day and if you guys did then maybe the bad chem injector would have been found. i would hve kept you there as long as possible and use your knowledge to fix the tm.
