Residue on Marble shower tile.
Yeah boy!
Thanks for reminding me about this one Greg.
I can only imagine they would have kicked arse.
X
XTREME1
I have that same shower scheduled in the beginning of november. That is why I searched marble showers
Soft scrub or grout that wasn't completely cleaned during post construction cleaning. It may be a good thing to recommend to custy a good clear semi gloss enamel heat lamp dried will protect and beautify/make it pop!!
A
alazo1
I have the ridgid palm and the ridgid 6 inch
A palm sander should work. May get hot and need a rest after some time though. You putting a shine on it?. If yes MPs should work if it's not too bad. Even if you leave a few scratches, it won't be too noticeable in a shower. Bring some wet-dry sandpaper to take out deeper etching if it bothers you (400 , 600 grit).
Albert
X
XTREME1
so we have this shower that I am monkey padding what do I charge?
L
Larry B
Works toilet bowl cleaner would have taken care of that in 30 seconds.
B
Bob Foster
Do you realize what toilet bowl cleaner will do to certain tiles?
L
Larry B
Yes I do Bob. But in the other side of my business the works toilet bowl cleaner is used almost daily in tile and stone showers with no problem. We do not and I dont advise letting it have any dwell time as we apply and remove.
The "works" is 20% acid so its very easy to see what can happen if you dont use it fast.
B
Bob Foster
Good to know because I'm not sure where acids of this type are safe to use and where their not. Maybe someone can enlighten us.
L
Larry B
The only problems we have had with this are
it reacts to soap scum (put on a mask & eye protection)
If its put on chrome for more than a few seconds it will streak the finish. (dont use on metal)
