- Joined
- Oct 22, 2012
- Messages
- 28,275
- Name
- Ron Marriott
So I got a Mytee ETM with a bunch of equipment I purchased from a guy who went out of business. This is the older 4 vacuum system with the 800 psi pump. Just got it home today from the mechanic and decided to take a look at it. What an utter piece of crap as a truck mount. You need 230 vac at 30 amps to power it. If you want to power it plugging into 115 vac circuits, you need 4 of them. Yes, I have all the adapters, no, I'm not moving the dryer out of the way. It does have lots of vac power. I am pulling 15 inches hg and it's seems like plenty of air flow. The pump is 800 psi and does deliver 800 psi. The only use I see for this machine is for implant use for surface cleaning rugs. Would be very powerful and coupled with a heat source, would be awesome. As a truck mount, not so much. The folks at Mytee should be ashamed of themselves for selling this pos to newbies. Probably the reason this guy went out of business. I think I will pull it out of the van and sell it separately. The van is in good shape. Mechanic went through it all, changed the starter motor, did a tune up, oil and lube and some minor things and it's good to go. Anyone thinking of buying a Mytee ETM, I have one word for you. Don't.
