Internal Jet Wands
Sapphires, have triangle vac chambers, which out perform your PCTI, I
hate
to tell you
I was referring to the old style wands that had the tall triangle heads.
Any results you get on your side of the country have no relation to the results over here. My results far exceed my customers expectations. Even if a sapphire wand dries 10min sooner. Goober
Maybe someday your cleaning results will exceed your expectations too....
Reactions: hogjowl
I'
Matt truly adds fuel to the quintessential ignorant southern man fire.
I'm not the one who does wet pullback triangle passes with a hole glide. Using the wand properly was one of the few things I paid attention to back in '03 when I took that IICRC class. For some reason, that went right over your head
One of the advantages of reaching an advanced age and skill level is the ability to discern between useful and useless information and practices. For example, truly practical information never comes out of a need to fill billable class time. It comes from experience and application.
Reactions: Austin Willoughby
It’ll be an improvement if it even picks up 50% of the water off of the floor
Mike J
Mike Joannides
I know you can figure out a hard surface glide for the PCQJ.........
Maybe I will try this... I bet you cant make a hard surface glide for the PCQJ
It would work great, as good as the SSTI12
But you would have to notch a wing, and most cant.
