Help me setup a Rug Shop
Not happy. I have a water leak at the shop. Spent the day digging it up and trying to fix it with JB Water weld. It’s still leaking. I got here early and applied another layer. I was hoping this would work because it’s a T-joint I’ll have to rebuild. The Genius that installed my sprinkler system didn’t put any shutoff valves in so, I have not running water right now.
Macy and I go through cold bottled water like crazy. Its been a challenge keeping up with the demand for ice and also not having a refrigerator at the shop has sucked. I found a working fridge with ice maker on craigslist for $50. Got it back to the shop tonight and installed it. Its a super tight fit.
I had to pull off the bathroom door, door trim, hinges, and floor trim to get it to fit. Also had to pull off the counter top. I'll need to cut the counter top down 1/4” on my table saw. At least I got it in and working. Now to stock it with Macy’s favorite drinks. She likes the Propel flavored waters.
So, when are you two moving in?
Reactions: Fat Mike
Fat Mike
AZ
Mike G
You didn’t measure opening first I take it
Reactions: Nomad74
You know the real solution to this problem. Move somewhere habitable. That isnt 110 degrees. I guess it makes it easy to get dry carpets, but besides that it's kinda miserable.
Today was 107°. I try and schedule the jobs so we're done by 2pm, before the real heat hits. It's hard on the equipment and our bodies. It doesn't always work out, but I try. I had three jobs scheduled today but when we got to the last job, it turned out to be 1,500sqft of urine soaked vacant carpet. I rescheduled it for Tuesday. So glad I have my 55 gallon drum of Saiger's P-Lyme. I have about 45 gallons left.
This place is going to take me 5 hours to clean with all the Urnine decon I need to do. UGH! I do love that blue nylon carptet!
Brian K
santa rosa
Brian Kraut
Heres a beginner rug clean question for you guy. Were do you all get your acidic acid from ? We've just been using fibers rinse like we do with our truckmounts but its definitely time to save some money and buy it in bulk for the rug plant. I really appreciate the feed back.
Thanks
roro
Wellington
Ross Craig
Glacial acetic acid - cheap - handle with care - dilute to suit
roro
p.s. haven't seen it in form Damon references below - we buy it in liquid form at 99% and immediately dilute it into 4 containers of getting a 25% mix. We find this helps avoid it turning into a solid block in colder weather conditions. When using we dilute further to get desired mix.
Colorado Springs
Brad Gouveia
roro
What is the desired mix?
roro
Wellington
Ross Craig
For a urine steeped rug we would go about 8%. We use a stronger mix for truckmount flush, from memory about 12% (away from office at the moment)
roro
