Electrical.......Battery
R W
My Genesis runs with a 12 volt, 450 amp battery. Would it harm the system to put a larger capacity battery in as a replacement? I was thinking of 600 plus amps cranking power. Powerclean is already closed for the day, so I thought I might pick the TM mechanics brains here.
joey895
Florida
Joey J.
Won't hurt, the more the better, you can't have too many amps only too many volts.
pcikeith
Yes, as several board members here have stated, a 600 amp battery is perfectly fine for that unit.
Keith Schuyler
Vice President
PowerClean Industries
R W
Thanks, all. I figured I better get a new battery in before I need it.
allpro
You may consider ill effects on the charging system, the manufacturer can let you know what is safe and what is not. Could be a life shortener on the alternator regulator etc.
La La Land
NAW....cold cranking amps jus determines how long you can grind a starter till it finally goes dED!
It's 12 VOLT!
