- Joined
- Oct 6, 2006
- Messages
- 117,319
- Removed corrosion from AT vac relief that was causing it to stick
- Tweaked the Dev14 to not be so fn stiff
- Wasted hours removing the bottom rubber strip on the AT's back doors, not realizing that they sent me the wrong size replacement strip. Hodgepodging up a temporary seal and cussing the whole time
- Replaced two plugs, Kirby and a Multi.
- New feed hose in a Multi
- New trigger on our best PC Titanium
- Swapped the AT water separator
- and the fule filter which is friggen nightmare job
- Organized two brass and jet boxes
- Tightened all AT coolant lines
- Turned two broken Sapphire tools into one working tool ( My lord but these dudes clean a LOT of upholstery)
- Dats all...time to go home
