Belt ?
Doug Cox said:
Let's clarify this Kevin. I have a fan mounted on the rear of the machine with the air blowing into the machine. Should I try the opposite or is this way you suggest? Thanks. Doug
Your blowing into the belts Im assuming,so yes I would reverse it to pull the heat in the other direction away from the machine and belts,and this should give you more time between breakage.Most fans nowadays are reverseable,just reverse the wires,then you will know.Where is your radiator?The fan in the back,is that your cooling system fan?,or an auxillary.
Sticky
White Collar said:
Oh I'm gettin a kiss, maybe more.
How much are specialty belts..? Maybe I should take it to interlink and get my kiss.
But I want to learn this crap.
Nappa should have that belt...if not call Scott and Blueline and tell him ur in a jam and he will give you the nappa part number...
John Olson
John Olson
napa doesn't carry industrial belts. at least the ones here do't.
C
Chads
I cant belive there is no one close to go help the guy out come on Mikeys board people. wuit talking and go make a friend help him out.
Must be a Utah thing,cause I get Gates industrial at Napa
