Bane Clean
John LaBarbera
Hi Steve,
Mytee can put the 500 psi pump in our 1200 psi Water Hog housing for him. He can contact any Dist. for this.
John
Thanks Steven, sounds like hte same fellow asking from ProCleaners, I told him exactly what John just said, as we have done just that, very universal, very easy to do.
Bob Savage
Bob Savage
Here is another option - our 600 PSI presure pump with chemical feed, thermal relief, gauge, and a carrying handle.
Blue Monarch
Dirk Wingrove
Yeah, price??? That thing is just plain cool.
Willy P
Willy P
vincent said:
The pumptec pumps, motors and parts do not and will not last very long at all.
The best thing to do is direct couple a general pump to a electric motor. High psi and durability.
AGREED
I am still waiting for Vincent to put out a portable that runs on two 15 amp cords with his direct coupled pump above.
Until then....it's just talk, and we are back to reality.
The pump-tec AC motors are rock solid, like any other AC motor (think 175 rotary).
The Aluminum pump heads are fine, (If you don't run caustic Bane chems through them), it's the wear items like seals and checkvalves that will require the annual rebuild if you use it everyday, or run 180 deg. water through them....it is what it is, a low amp draw, compact, efficient pump option.
Bob Savage
Bob Savage
Our 600 PSI pump system sells for $770, and includes a very reliable chemical injector system. This unit will operate from direct faucet pressure, a fresh water tank gravity feed, or will even draw from a 5 gallon pail of water.
It's light, and will easily go anywhere.
Bill Soukoreff
Bill Soukoreff
rjfdube said:
Another modular option; Cross American Shockwave $960
Rickie, isn't it about time for you to find something here that you can post on the Recoil board?
BTW, who is desperate? You never clarified that?
