Aramsco acquires Jon-Don
Yes, I’ve done both, of course, and the Rotovac leaves no damage if you’re using the conventional head and moderate damage with the brush head. If I’m using the brush head, the carpet is so bad that replacement is the only other option so it’s a moot point.
We ALWAYS follow up with a glided wand to remove the swirls.
PS You were reaching hard on that one.
Lc17smp
Dallas
Larry Cole
I am new to VLM and absolutely a believer after cleaning over 350,000 sq ft with my Vibe so far. That said I would not even think about using my vibe in a customers home instead of my truck mount. I can think of a handful of homes I have cleaned with carpet that I would consider doing. All I have to do is walk upstairs at my house to be reminded what an OP can do. It does look amazing and even my wife thought it looked better than TM room I cleaned next to it. However the next day you couldn’t tell the difference as they were both dry and in a problem area where I did a little extra scrubbing with the vibe it messed up the carpet. Can’t really tell once it’s groomed but the carpet (cut pile) started separating. (Untwisting)
I could OP everything as I have the option but I know from personal experience and testing it out on several different types of carpets it’s not always the best option. OP is easier in certain cases and certainly way less overhead but that doesn’t make it better. Also I have about 2 customers a year that need their carpet dry asap. It’s very rare and if needed I will do extra dry passes and run fans. I’ll be making a bunch of money with the vibe in the next couple of weeks. It will be on cgd in buildings where it’s not practical to run my TM. Also there is no way I could be faster with an OP in a trashed room than I am with my TM. OP wins in large areas. Very large.
SteamwayPro
USA
George
Sounds like a chemdry marketing tactic
It might sound like a Chem Dry marketing tactic but it's not
It's my marketing tactic and I use it
POWER WASHING carpet using water pressure to clean with and long dry times is how carpets were cleaned in the 1990's
Water pressure just drives dirt and contaminates down deeper into the carpet to the carpet backing making them impossible to remove
VLM uses 60% less water than Steam Cleaning
It's not the 1990's anymore
It's 2025 and VLM with 1-3 hour dry times is how carpets are cleaned today
After talking to customers about VLM a lot of times they then tell me their HORROR STORIES about the hours and hours of waiting for their carpets to dry after having them Steam Cleaned. Most of the time but not always by Stanley Steemer. One lady told me a story about how she had to get a shop vac and try to suck up water from her carpets after having them Steam Cleaned because they were so wet but that wasn't Stanley Steemer. It was Sears
I clean move outs for one Apartment Complex. They tell tenants not to clean the carpets themselves and not to have them Steam Cleaned especially from Stanley Steemer. They're tired of that musty odor and dingy looking carpet because of over wetting and long dry times. True story. I'm not making that up.
All apartments in the complex must be inspected by Township after a tenant moves out and before a new tenant moves in. One of the requirements to pass inspection is carpets must be cleaned. Complex doesn't want them Steam Cleaned. The tenant can get them professionally cleaned and must have receipt for proof or have the Complex have them cleaned. The Complex recommends me for the carpet cleaning. If tenant doesn't have them cleaned I clean them for Complex and payment gets taken out of tenants security deposit
Yes I know you guys do not do that kind of work but there are a lot of Steam Cleaners I call them SOAKERS out there giving all carpet cleaners especially Steam Cleaners a bad name. I take advantage of the SOAKERS and get more jobs promising 1-3 hour dry times.
Most customers today don't care about method. They just want clean dry carpet
I love VLM !!!
SteamwayPro
USA
George
Use it most time for prescrub. Carry it with blue brushes used often. Also carry white brushes for rugs and delicates. Also carry yellow for the worst of the worst dead zombie carpets.
Whittacker purchased years ago as a package with their crystal encap. Stuff last a life time. JiMmy was right.
I do some doctor offices and dentist offices and use Crystal Dry. No odor Green Seal Certified and does a great job
SteamwayPro
USA
George
When using a CRB you must have the right brushes for the carpet
Brushes for 14'' Brush Master Pro 35 CRB
White is very soft and used for nylon
Grey is soft and used for abused nylon and polyester
Blue is medium standard brush that comes with CRB and used for abused polyester
A CRB with the right brushes is a must have for Residential Carpet Cleaning !!!
I love VLM !!!
"Power Washing" is far from the truth and "Steam Cleaning" is far from the truth also, which tells me you didn't know much about Hot water Extraction
And yes, it's a Chemdry false marketing tactic.
I went to a little local business expo in my county way back in my early years and I noticed chemdry had a booth there to advertise their business. So they put the VHS tape in this little tv to show their "process" of cleaning. Most of the video was all showing someone improperly cleaning carpet with a wand. they must've had that pressure turned up to 1200psi with how the water was spraying all out the side of the tool and was going so slow, allowing it to literally "Pressure wash" (not power wash) the carpet. It made me furious to see the corruption in false advertising. Look up yourself an older chemdry video
I agree, it isn't the 90's anymore. And today's truckmounts are wayyyyy better with more suction, better tools, (glides being one of the most important), better chemistry, and better education
But keep buffing that carpet.
Reactions: jessi
SteamwayPro
USA
George
I agree HWE is not Steam Cleaning
VLM is called other names too
Yes of course TM's are much better today than the 90's
But there are still a lot of SOAKERS out there and yes there are a lot of Diaper Spinners BUFFING carpet out there too
There are VLM'ers that go out and clean with just a Oreck Orbiter
Plenty of bad on both sides but I'm VLM so I use the SOAKERS to my advantage
SteamwayPro
USA
George
I don't like to point fingers at others to make myself look better.
Stanley Steemer makes everybody in the Carpet Cleaning business look bad
Get in, get as much money as possible, get out as fast as possible, get to next job
SOAK and leave !!!
SteamwayPro
USA
George
I've been told that not all Stanley Steemers are that bad and I believe that. Like everything it depends on the owner but I get complaints about Stanley Steemer a lot. So whoever owns the Stanley Steemer in my area sucks. Like I said The Apartment Complex I clean carpets for don't want Stanley Steemer on their property
they live
Michigan
Steve
SOAK and leave !!!
I let the customers complain. I try to keep it positive.
Focus on what you do not what others do.
Reactions: jessi
Dr. Kleen
New York
Jodi Fandozzi
I love VLM !!!
Just because you say it over and over doesn’t make it any more right or wrong…
SteamwayPro
USA
George
I like CONFLICT !!!
I like taking on Mikey's Board
GROUP THINK !!!
It's 2025 you must learn to THINK and REASON for yourself
I used to be like you guys. Closed minded living in the 1990's
You have to flood carpets with gallons of water to clean it
WRONG !!!
LESS water MORE agitation !!!
The number one question I get is NOT where did the dirt go
It's how long will it take for my carpets to dry
VLM with 1-2 hour dry times, in most cases, is how carpet is cleaned today
I love VLM !!!
Dr. Kleen
New York
Jodi Fandozzi
I like CONFLICT !!!
GROUP THINK !!!
WRONG !!!
I love VLM !!!
Now I’m starting to think “age related dementia”...
Reactions: Nomad74 and hogjowl
SteamwayPro
USA
George
Your "Power Washing " term is cute. You gotta say what you gotta say to the customer I guess. But you are conveniently leaving out the extreme suction that a truckmount has removes the moisture that you falsely claim has been "power washed" into the backing. That's like saying rubbing your hands together with soapy water pushes the dirt deeper into your pores.
POWER WASHING carpet using water pressure to clean with just pushes dirt and contaminants down deeper into the carpet making them impossible to remove
HWE leaves behind a lot of dirty water. The longer it takes to dry the more dirty water left behind. 4-6-8-12 hours to dry that's a lot of dirty water
We have all heard the stories about carpets taking 1-2 days to dry
VLM uses 60-70% less water than HWE
If done correctly VLM dry times are 1-2 hours in most cases
It's not the 1990's anymore !!!
Hope everybody has a wonderful Memorial Day !!!
It doesn't say into the backing ... it's says ... down deeper into the carpet
In some cases I have said ... down deeper into the carpet to the carpet backing
I know you guys are going to pick apart, analyze, criticize, in this case misquote, every word and statement I make. I know I can't make any mistakes but I will
Just don't MISQUOTE me !!!
POWER WASHING carpet using water pressure to clean with just pushes dirt and contaminants down deeper into the carpet making them impossible to remove !!!
I's not the 1990's anymore
VLM WORKS !!!
I know you guys are going to pick apart, analyzed, criticize, in this case misquote, every word and statement I make. I know I can't make any mistakes
VLM WORKS !!!
Power washing? Which power did you use when you cleaned with a truckmount? The power of He-Man or Shera?
The power of He-Man I think came from the power of Grayskull.
Reactions: Kenny Hayes
Yukon, Oklahoma
Honestly, it’s not even a debate. I know there’s vlm chems for residential, but since you used a truckmount, I’m not quite sure how you can make the comparison equal. Even with an entry level truckmount, there’s no comparison. How many times does it need to be said. Apples and grapes!
Reactions: Dr. Kleen
