Another use
Here is another use for your hard surface cleaning equipment. These are concrete balconies that can't be power washed due to the over spray. We block the drains and clean with a 1200 psi pump, old ninja for vacuum and an assortment of floor and hand tools. This particular one I presprayed with code Red, wire brushed a bit and rinsed with procyon.
Old Coastie
Heart of Dixie
Stephen
I was sort of doing that in my basement. Apparently Gadsden had a couple of near tornado misses while I was in Birmingham. My outside cellar steps were filled with blown debris and clogged up the drain so once again, I find myself slurping out the guest room.
Maybe this weekend I can build a little dam across the front of the steps so it quits happening.
