- Joined
- Sep 15, 2007
- Messages
- 44,657
- Name
- bob vawter
I break every grandy groomer I run across !
How can anyone be that dumb?
I was born that way!!I break every grandy groomer I run across !
Its not his problem.I was born that way!!
Do you have a problem with THAT??
GOOD!!!------------Its not his problem.
If you know how to wand, you wouldn't leave little or big trees BobI break every grandy groomer I run across !
If beginners would do the dual process,ConDog is not, I repeat, is not going to the dark side. Where you been Con? Y'all just skipped right over the two porty extractors. THAT makes him a dual method cleaner when the need arises. Not real sure you could put him in the VLM only category.
I’d put him against any truckmountConDog is not, I repeat, is not going to the dark side. Where you been Con? Y'all just skipped right over the two porty extractors. THAT makes him a dual method cleaner when the need arises. Not real sure you could put him in the VLM only category.
