Where do you mount your Ozone Generators?
I work within the confines provided.
Higher the better.
Ozone is heavier than oxygen and will build up concentration lower. We use a 6 foot ladder bungee the unit to it. Put weight on the ladder if needed to keep it from being top heavy.
You can also use a low volume airmover to distribute it. The Stealth works well for this.
Make sure you air the space out before re-entering.
Higher the better.
Good idea. I dropped in a stealth fan for some air flow.
Reactions: Desk Jockey
I put in fans too and bounce against the walls in a circular motion.
Reactions: Nomad74
I just bought a new ozone generator. 9000 mg per hour. Should be an improvement on my oasis which is 2400 mg per hour. $950 made locally.
Reactions: Nomad74
I got mine for $85 each from homedepot.com and they’ve made me thousands. :)
