Using an RX 20 with a portable
B Reid
Monrovia,CA
Brian Reid
Got a call to clean carpets in a condo. Transmission went out on van so can't use the TM...
So what did I do
Pulled out my low pressure portable that was in a corner of my shed for the past 7 yrs. and hooked up my RX20
End results-
looked like I used my tm to clean the carpet
happy customer
$350 dollars richer.........And proved the distributor WRONG
Quote: You can't use a rx20 with a low pressure
portable
I dont know why you couldn't.
You may just have to allow the porty time to keep up with the water gulping Rx.
But then .. the portys pressure.. had the RX at its mercy.
And you did do it like a TM.. as both are HWE..
I can make my jobs look as great with a porty and rotary. But not as efficient. Thats wherer we lose,, TIME>. in set up.. teardown.. and the mess of hauling water. hooking up hoses.. etc.
Portys are inefficient. Not bad machines.
Do they have as much vac or heat? NO.. but you can work around that. It just takes more time.. but it's do'able.
If i had a porty.. i'd make any new tech learn on that and a rotary and all types of pads.. old school.. then graduate to the technnology..
'Always know where others have came from.. so you know better where you are going"..
roro
Wellington
Ross Craig
Steve - That is utter crapola. Try comparing a low end truckmount with a high end portable.
roro
ps Sorry this post is so short ; knowing you are the antithesis of Marty you probably won't read it. :p
That goes to say in any industry.. Ro Ro
I doubt Mr. Reids porty was the higher end as some of the present models are.. with a higher heat output.. and really high pressures for working on tile and grout. Afterall.. he said it was out in the 'shed' for the past 7 years. lol
yes.. I agree.. newer porties would out'do... a lower end TM.. (or could with a competent operator behind the wheel).. But thats not what he said..what i said.. or what the thread referenced.
Indy car engines blow away Nascar motors.... but again, that isn't what was asked.
Dont try to put words in my mouth.. pleeze.. as I assure you you're are neither qualified or as articulate as myself. respect or disrespect intended.
You decide! (I'm winking at ya sweetie pie)
I'm sure a newer, higher end porty is probably nicer than most cleaners TMs..
I have seen the normal hwe TM.. and its pretty sad..
HWE'rs are our own worst enemy.
did I say it couldnt be done with a porty? NOPE..
It can.
Did I say portys were junk? No.. i said they were inefficient. And anybody will tell ya, MOST porties lack heat and vac.. you merely have to learn to work around that.. and u se it til you can upgrade.
Get with the thread.. or swaller' an anchor and jump overboard buddy.
A little advice.. "look before you leap".
lol
Calm down. Step back.. take a deep breath.. and get your panties out of the wod' they are in. I think you 'sharted'.
I'll accept your apology. No worries mate.
be well.
GRHeacock
For a lotta years, I used a low pressure (100 psi) portable with both a RX-20 and a Chemstractor connected to it for the high rises- residential and commercial.
Sure it can be done. I did hundreds of these jobs.
Not as efficient as a Truck Mount, but on the 26th floor of a building, it was the best way to do the job.
Gary
It is you
not the machine. I compete with the big boys everyday, but they just don't seem to get it right. And, sometimes I don't either. This time you got it right.
alazo1
San Jose, Ca.
Albert Lazo
CD starts you off with that combo.
I too did very good work with it and made a lot of repeats. I then got a tm. Sometime ago the tm was down for a while and had to go back to porty. Damn, all of a sudden I forgot how to clean. Actually I don't think it was that I forgot but more so how impatient I was.
Albert
Frank P.
Porty & I
Today we tried out our new Eclipse from Clean Craft on my neglected carpets, (6 months). My house is older and somewhat small, Built in the 40's. The wiring gave us trouble since you need a 20 amp & a 15 amp circuit. Our unit has auto fill & dump & chem metering. With all those wires, hoses and tight areas I was getting annoyed. All I could think about was how easy it was with a TM.
All that being said, the results with this 300 PSI, 3 vac machine were as good as I remember the Butler TM I borrowed from my brother in law the last time I cleaned the carpet. Plus the carpets were mostly dry with the aid of a CFR Downdraft fan in about an hour. One exception was the two sided area rug in the dining room. It took a bit longer since we cleaned both sides.
Maybe we were using better emulsifiers & presprays that helped clean better but so far this porty seems to be working pretty well. Oh the wand is from Greenie. It is a hole glided 12 inch SS wand. I removed the 11003 Uni jets and replace them with 110015 jets because we were using too much water. With the new jets we also had 300 PSI instead of 225. I was also surprised that the heat was fairly hot with only 1 heater. My circuit breaker would not let us use both heaters.
Frank P.
roro
Wellington
Ross Craig
lol
be well.
My humblest apologies effendi but on behalf of all us heat and vac challenged portable users thank you for your amendment -
A little advice junior read before you post :)
