Turbo-Hybrid TH 40 Questions
RugWorx
MIshawaka, IN
Joe Couch
Just got mine delivered and wanted to know recommended starting pressure to clean ceramic tile (I assume 800-1000 psi). I also would like to know if you recommend the brush head over the hard boot ring. Last question does it need any mods done to it?? Thanks again for all the help.
Trip Moses
IMOL
Savannah GA
Trip Moses
1200 psi. Brush rings moves better over lippage. Hard ring recovers better, but will make you cuss. Hard ring well also scratch natural stone floors.
Reactions: Mark Saiger
Trip Moses
IMOL
Savannah GA
Trip Moses
It operates best at 1200. I’ll use lower sometimes, but I seem to always turn it up. If you pre scrub the grout lines you will not need the higher psi.
