Rotary Machine
Sergio
Italy
Sergio
Hi,
i bought a new rotary machine for washing oriental rugs. It's a ghibli SB 143 L 13.
Technical Data:
Working width - Ø brush mm430
Brush speed rpm154
Voltage V220 - 240
Frequency Hz50
Brush motor rating W1300
Brush contact pressure g/cm²40,8
Under-ride height mm330
Dust pick-up attachment yes
Noise level dbA<54
Transmission planetary gear box
IP code IPX4
Power supply cable m12
Weight (without accessories) Kg41,5
Dimensions mm1200x542x430
Do you think that it's too heavy for oriental rugs?
Thanks
Reactions: Sergio
Sergio
Italy
Sergio
All three have merit. The first is a prespray which can be scrubbed in with your machine then rinsed. The shampoo has less wetting agents and the citrus is for greasy messes.
What do you mean with "The shampoo has less wetting agents"?
