Auction Ronald McDonald House Auction #13- Rotovac 360XL w/ choice of head
Rotovac Inc has stepped up to the plate to help the Ronald McDonald House @ St Pete with this stellar Rotary Extractor.
Up for grabs is a half horsepower "XL" with your choice of head
New models are 3/4 horsepower. I have the 1/2 and it works fine with the teflon port/brush head
The Rotovac 360XL is a Patented Rotary Extraction Power Head that utilizes rotary vacuum heads to thoroughly deep clean carpet with hundreds of multi-directional cleaning passes. The 360XL weighs only 68 lbs and is extremely easy to use as it operates in a self propelled side to side motion. Simply stated, “The 360XL cleans better with less effort."
Works with most Portable Extractors or Truck Mounts
The Rotovac 360XL is air flow calibrated to work with most portable extractors or any truck mount extractor. Give your business a boost and your back a break by hooking up the 360XL to your existing portable or truck mount.
  • Cleans better with less effort and leaves carpet drier than a wand
  • Large 15" wide cleaning head
  • High torque motor with tough helical reduction gearing
  • Patented Swoop Glide™ vacuum ports
  • Telescoping handle for compact storage
  • 144 RPM
  • 55 lbs (without cleaning head) 68 with head
  • Rugged cast aluminum frame
  • 2" clear view tube
  • Unique marketing tool, land new accounts and generate referral business
Retail value is $2500
Auction starts at $900 with $25 minimum bid increments
Free shipping to the lower 48
Auction ends Saturday January 28th at 6PM pst
Reactions: GreenTechAgain
