- Joined
- Oct 7, 2006
- Messages
- 12,630
- Name
- Jim Pemberton
Why do you change brands or models within the same brand?
Just get a hydramaster titan and you wont loose anything just gain the reliability.Doug Cox said:To be honest, after all the crap I've been through in 2 years, I will probably go back to Hydramaster if I buy another mount. I'll give up the vac and heat for reliability.
Ron Werner said:The thing with electric Danny is that you are still burning fuel. Doesn't the Savage run a generator?
Or if you plug into the house, the electricity has to come from somewhere, its just not as "visible", it appears very green, yet there is a power generating plant somewhere burning something or damming up some river.
Ron Werner said:Dual regs wouldn't be too hard to rig up. Just need a pump that will keep up with the flow.
You could even rig up a remote regulator, ie run whatever length needed to the house, then into a T fitting, with a regulator on each side. Don't know if a 1/4"hose would handle the flow or if you would do better running 3/8 to the house, much the same as the vac system running 2.5 to the house and 2" inside.
:roll:
