laminate flooring can I clean it with buffer
TConway
Thomas Conway
I have a customer that asked if I could clean Laminate flooring for her?
My question is...Can I clean it with a 175 and cotton bonnet and a spray bottle with a little cleaning agent in it?
I do not want to over wet it, so do you think if I sprayed it with a little 1 or 2 quart pump up spray bottle to give it just a little moisture and cleaner and use the 175 with a cotton bonnet would it work?
I haven't seen the floor yet, so if this will work at least I would have something to go in with, all I do know it is a large living room floor with Pergo type panels.
Thanks
Or if there is a better way to do it I would like to know.
Reactions: thecleaningdude
Royal Man
Use Laminatorsplus on it. You won't need a buffer, its easy and the results will kick ass!
Reactions: TConway
thecleaningdude
This sounds right. You might want to try a fiber followed by a microfiber or cotton. Do you have any Laminator Plus?
Reactions: TConway
I have cleaned several laminate floors with a buffer and either a cotton bonnet or a microfiber pad.
If the floor has any "proud edges" (i.e raised edges that can be caught by a buffing pad) then use an extra white pad between the machine and the bonnet to give a little cushion. Be careful of the edges.
Hydro-Force Wood Fresh Cleaner does a great job on laminate. If hard water is an issue you in your, distilled, or other water with no minerals in helps the shine to really pop.
Old Coastie
Stephen
I use a steam mop and non-ammoniated window cleaner. Spritz and mop. Dries in seconds, works like a charm.
TConway
Thomas Conway
Thanks guys for the posts, just wanted to make sure I was on the right path, as I have seen these floors and all the joints have swollen, maybe due to the fact that people have just used a mop to clean them and over time they have swollen and look like crap.
D
DannyJr3rdGen
You should try the Bona products! I have been hesitant to clean laminate floors as by the time the customer called the floor needed to be cleaned by water. I ran into the Bona products and Wow it sure did an amazing job to the floor and almost brought it back like new. Good luck
Todd Millar
I have not used the Bona products but I have talked to some guys who just do wood/laminate floors and that is all they will use, they swear by them.
Use that buffer and a pad and then use a NO-RINSE floor cleaner you can get anywhere.
Reactions: TConway
Every Janitorial shop across America sells a no rinse neutral cleaner for $10 a gallon. One ounce per gallon is all that needed
It's exactly the same as Bone floor cleaner which run between $8.00 -$10 a quart RTU
600 rtu quarts for ten bucks.
Tell your home owners..
