Heat that Glide!
Over a decade of Prochem Titanium use had me spoiled..
I never needed to heat up a Glide to get it on or off.
Installing anew Hole glide on the Dev 12 without it was impossible.
3 minutes with a heat gun on high moving quickly back and forth did the trick.
My concern is removing it without damaging the holes.
Btw, a chisel works better than any flat head for removing a Slot... Grind down the edge of you want to get geeky about it.
1900 North
Provo, Utah
Richard Swan
If you follow Tom’s glide install suggestions, no heat is needed, the glide just snaps into place. I heated and beat my 12 inch hole glide and couldn’t get the silly thing on. Then I followed Tom’s directions. By the way, Tom’s glide fits the best of any glide I’ve owned. It fits the wand perfectly.
That’s why I called him an idiot
Tom had a video it so easy
he watched the video and still did it the hard way
Reactions: hogjowl
Hole.
