dry cleaning solution
campusman1
i had bought a 5 gallon pail of fab pro dry cleaning solution for some drape job that never came. i hate to let this sit and go to waste is there anything for me to use this on throughout my daily cleanings and i relly dont do any dry cleanings. thanks campus
Jose Smith
Pre spray fabrics that you think might be "moisture sensitive". This will create a moisture barrier that will prevent the fabric from getting too wet during your HWE.
A good example is any print.
Jose Smith
You can use it for removing grease, gum, tar, cosmetics, vegetable or animal oils, etc. In short, anywhere a volatile solvent would work.
Make sure that you don't over apply it, as it won't evaporate as quickly as a volatile solvent, and it could contribute to delamination or resoiling.
