Do you give a new chemical a 2nd chance?
Shelbyville TN
One job is different from the next. Different soils. Different soil levels. Maybe different water. Etc. I try products on several jobs before I make a decision.
I would not however, do a large project with just a new chemical. If the new juice did not cut it, I would have my favorite on standby. Testing it out on several jobs does not mean I would be committed to it for cleaning every inch of those several jobs.
If it fails miserably the first time ?
Cleaning failure? Did it not clean something heavily soiled, but you had no way to compare it?
Try it again when you can test it against a proven product.
Did you test it side by side with a product that you know should work on the same job, and did it underperform with the same soil?
No need to test it again.
The same goes with protector.
Deodorizers are the toughest, because its difficult to do a "side by side" using smell as the only way to know it worked. Unless you have an area rug that is evenly contaminated, and you cut it in half and work on each half in different rooms, you can't always tell.
I tend to give deodorizers more testing for that reason.
Acp
Seattle
Bjorn Marshall
I give a new prespray 1 case or 40/lb bucket to impress me but if it fails miserably on something I feel like it shouldnt have had a problem with then I might only run it on one or 2 more jobs.
Benton KY USA
Sometimes the second bucket is way different from the first.
I remember vendors putting out awesome "samples" that the subsequent order never equalled.
Reactions: Bob Savage
A "miserable" fail is one 'n done
an "unimpressed" mediocre result might get a few more tries..but not many
I've always taken the time to do side by side evaluations against proven performers though
It's the only way I know how to separate the wheat from the chaff out of the gate
and avoid all this
Acp
Seattle
Bjorn Marshall
If its marketed as a lighter pre spray then it doesnt bother me but when they sell it as nuclear and it sucks that pisses me off
