APO's
I am going to add a shut off valve to the waste tank for the APO......
I want to add a filter to the line after the shut off........
Any ideas what type or kind would be good for this something that will allow the flow for the pump but still catch the crap..........
I myself do not use my APO I turn it on now and then so it don't freeze on me.. I have had to clean lint and crap out of mine and I have pulled another guys apart twice now for the same reason.........
I think a better idea would be to put a six inch long pipe into the apo hole in the bottom of the waste tank to keep the crap from ever entering the system.
I so rarely use mine that I have taken the time to try and make something.
Just another shitty AT design.
You would be surprised to learn all the small things like this the Shawn had no control over.
from what I am seeing and hearing there is a load of things
I thought about the pipe idea just not sure what the difference would be
Can't filter it inside the tank the thing would clog and not work and you could not get to it to clean it..
I was thinking maybe a upside down "U" shaped pipe.
Hook it in the existing hole and have the other end about 2 inches off the bottom of the waste tank...not really sure this is the right answer either.....
