A few photos of the O2 system
Wandslinger
Simi Valley
Tom Meyer
This photo is turned and is the same area you will see in the other photo. It captures the corner of the bed towards the nightstand area
Wandslinger
Simi Valley
Tom Meyer
Nate,
Come on now, you just love the MSG thing don't you. I was just playing off of Mustertitties after I asked Mikey P what all this MSG thing was about. You even ribbed me at the Jon Don party. LOL
joeynbgky
Bowling Green
Joey
Well, I tried my o2 system for the first time today...... Let me say this............ MY next Tm wil be a judson...... But for the system. It worked ok on plush carpet. On berber it didnt even get close to getting the black spot that lines the front of the sofa. And alot of other stains. So I went over it again and pre-sprayed a second time. no better at all. Grabbed grease eater. and bam looks like new. Now, I am not done testing this product. So in case it was just this one time. I'll try it again. i did use the hotsauce with it.
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
Scrub it in, or longer dwell time next time.
George Valliant
Its a very good quality liquid pre-spray. However, I don't think its gods gift to carpet cleaning all the cheer leaders here would have you believe.
joeynbgky
Bowling Green
Joey
I gave it 20 minutes on one room and longer on the other. I will definitely try it again. So i make sure its not operator error. It does smell good though. I think i might go try it tonight on another apartment, just curious. its 5:30 so maybe tommorrow.
joe harper
florida
joe harper
Might I make a SUGGESTION here... :?:
I have a CUSTOM juice ..prepared for my business...For over 20 years... :!:
I moved the office JUST 6 miles....&....started to experiance a DROP in cleaning Performance..
I contacted my supplier...He assured me that there was NO change in the formulation... :?
I was having to DOUBLE my dilution RATIO's... :x
After many conversation's with him on the phone..."HE"...noticed that I had changed my
shipping address.. :shock: ...He then requested that I ship him a gallon of water..from my
NEW location... :!: "BINGO"...He said that the "city water"... that I was NOW using was
LOADED with SODA ASH.... :!:
This change in the "PH"of the water ...was diluting the strength of our formulation... :!:
He added a booster to the formula....&....BAMM...cleaning better than ever. :D :D :D
So....If some of you are NOT experiancing....The same RESULTS as OTHERS..... :idea:
Contact "Les"..and he MAY be able to suggest a "booster" that will overcome your HARD water.
It is DAMN NEAR....Impossible to the PERFECT pre-spray...When everyone is mixing with a
DIFFERANT..ph of water.... :wink: Don't give up on the Judson products...Les can SOLVE
any of the issues that I have posted here...My guy sent me a 100lb bag of the booster @
NO charge... 8)
Hope this helps... :roll:
ACE
Lawrence, KS
Mike Hughes
Yea, it must be the water here because the O2 Juice doesn’t outperform the other quality pre-sprays I use.
steve g
herriman, UT
steve garrett
exactly keep in mind most of the guys singing the loudest have been given cases of juice to do it. just about any prespray will work great if you scrub it in, the real test of a well formulate prespray is how well it does WITHOUT scrubbing.
Stevie,
I totally resent your accusations about me giving free juice to someone and that this little gift of juice is enough to cause a guy to lie about my products on the board and go to Hell for lying. As far as scrubbing a carpet goes, that is the proper procedure for carpet cleaning. Agitation is extremely important to disperse the pre-spray to the bottom of the fiber, no matter whose juice you’re using.
When I first introduced the O2 System, I did give away over 200 gallons free on a first-come/first-serve basis. This was the first time any chemical manufacturer in this industry had ever given away free gallon samples of their product. Then the members of the board posted they liked my product. I did this so I could see if I had a good product or not. I welcomed any feedback, good or bad, so that I could make necessary adjustments to the product.
SRI Cleaning
West Chester, PA
Anthony Firmani
The bottom line is if you are going to compare two presprays, then you have to keep the test consistent. If you always prescrub then prescrub with the new juice, if you never prescrub, then dont with the new juice either. Keep it consistent.
Joey,
I’m in the process of making a work manual for the O2 System for different types of fibers. For an olefin carpet, the proper mix ratio for the O2 System would be 2 teaspoons of Hot Sauce Modifier mixed in warm water first, and 4 - 6 ounces of the O2 pre-spray per gallon of water. The O2 System is a low Ph system to make it safe for wool and 5th generation carpets. Before the Hot Sauce Modifier was developed, you could have gotten good results with the O2 pre spray on olefin by mixing it at about 8 ounces per gallon.
joeynbgky
Bowling Green
Joey
Les, thats great. That helps.. most manufacturers dont give all the right directions. your on the right path.. As soon as you get that I would love to have it!!!!!! it will help so much thanks.
George Valliant
NO charge... 8)
That's cool... My style is a little different. I'm having more fun using powdered detergents and arguably getting better results.
Besides, the stank I use has built in water conditioning surfactants included.
The juice is cool too! Currently, I use it exclusively for upholstery, area rugs and gum removal.
I really do like the JJ. Deliminine products are nothing new to me. Started using them before Joe Polish became a guru. The JJ is the best darn deliminine based product I have ever used.
sweendogg
Bloomington, IL 61704
David Sweeney
I use Hydraforce and get great results with JJ.. I also get good results with alot of other different presprays as well.. and for the record.. I've never been given any free samples to try.. I had to fork out the money to find good products that work effectively. And I like JJ. Like Les said if you encounter a crap ton of carpet fibers per day.. its great.. If you know what your cleaning before you go out in the morning, you can mix the absolute best product you can find for the best job.
Damn Stevie, that is strong accusation.
I have a pretty damn good idea who gets what, and nobody getting free stuff from me to run their mouth, I don't need 9 out 10 to re-order juice, just 4 out of 10 will do....lol
I still say an ounce of pH 8 Judson juice will out clean an ounce of any pH 8 product you have on your truck.
gary mackay
I like the prespray but ever since I dumped a gallon in the truck last year I have a severe phobia.
Ken Snow
RIP
Bingham Farms MI
Ken Snow
Les- if I had a nickel for all the free gallons or cases of gallons of products I have been given free by manufacturers and distributers I would be rich. I have no opinion on the product or this thread except for that. Smart manufacturers and distributors lilke yourself give out free stuff all the time to do exactly wqhat you are doing and I say kudos to all.
