is this your van?
they live
Michigan
Steve
It needs cleaning but I'm still recovering from having 17 teeth pulled and fighting autoimmune problems.
Doug Cox
Delavan, WI
Doug Cox
I just started lining the walls ceiling and walls in my van. I insulated and lined the ceiling today. Now I have to pull the recovery and water tank to do the walls
sassyotto
Wisconsin
Paul
I just started lining the walls ceiling and walls in my van. I insulated and lined the ceiling today. Now I have to pull the recovery and water tank to do the wall\
im assuming you are insulating the walls for cold weather. Do you use a space heater in winter?
Doug Cox
Delavan, WI
Doug Cox
The ceiling liner has an r value of 15, I added an additional 10 with 1 1/2 foam board. I keep my van in a heated garage in winter but if I leave my current van outside with a heater, it barely keeps it above maybe 40. My old van would stay at 65 with a heater in it. The liner is more for optics and sound control.
Dwain Ray
Wanta see "baby pictures? " This is my baby and main van Frankenstein its a 2020 checy extended 2500 with a custom designed and built steamgeni pto with modified cleanco driveshaft mount steamgeni driveshaft,frame, modified 50 gallon waste tank and stainless waterbox, all stainless fittings and stainless reinforced teflon hoses hypro pressure pump with general chemical pump cleanco new style heat exchangers hydramaster salsa afterburner roots 47blower comet p33t pumpout system. Custom shelfing 11strings of led lighting with 12vdc & 110ac power supply waterpond etc etc and yes this is how it looks all the time 1,200 on the clock and 53k on the van
20221101_184922.jpg 20221101_190558.jpg 20230528_153110.jpg 20240122_134136.jpg 20230521_172952.jpg 20230521_165006.jpg 20230505_150142.jpg 20230224_160521.jpg 20230126_142157.jpg 20221101_190636.jpg 20230902_174746.jpg 20230910_143327.jpg 20231015_155616.jpg 20240428_132955.jpg 20240603_101052.jpg 20241128_150515.jpg 20250413_140438.jpg 20221229_105637.jpg 20221229_105658.jpg 20250208_160041.jpg 20250212_152618.jpg
jessi
Idaho
Jessi Lopez
View attachment 130625 View attachment 130626 View attachment 130627 View attachment 130628 View attachment 130629 View attachment 130630 View attachment 130631 View attachment 130632 View attachment 130633 View attachment 130634 View attachment 130635 View attachment 130636 View attachment 130637 View attachment 130638 View attachment 130639 View attachment 130640 View attachment 130641 View attachment 130642 View attachment 130643 View attachment 130644 View attachment 130645
Paint the van green
Dwain Ray
Why do you have a lighted picture of Mikey on your dash?
That switch is the master switch to my entire truckmounted systems. It energizes the relays that power the entire back of the van 3 relays and circuit breakers controls everything 1 relay for waste pumpout,1 relay for waterpond& shelf lighting, and 1 for the pto itself. This little box is my entire electrical system for all my equipment in 1 place instead of fuses i have circuit breakers with manual resets 30a circuit breaker for wastepump 25a for waterpond 20a formachine and 7.5a for frankinstien switch,throttle controller and safestop ( allows van to run with key removed from ignition) where the main power taps off the van theres a 100amp master fuse to protect the entire system
20190420_132409.jpg 20190422_153248.jpg 20231119_150745.jpg 20220410_164526.jpg Screenshot_20240211_170058_Chrome.jpg Screenshot_20240211_170136_Chrome.jpg 20220213_152718.jpg 20220213_152702.jpg
