Large foil tabs
sassyotto
Wisconsin
Paul
I have been using these 5 x 10 inch large foil tabs, mainly I tear them in half and put them under doors that touch the carpet.
I had another supplier but they have not answered the phone and Bane does not sell them anymore.
Is there another company that sells them?
I use 4 inch tabs or sticky tabs. Anything larger I put on blocks.
Are those tin sheets that you buy for restaraunt food wraps the same size you need? I’m sure any food supplier can get you a couple boxes
Brian H
Detroit Michigan area
Brian H
this is mainly for under doors that touch the carpet. cant put blocks under doors.
I started in the cleaning business in 1982 and on my first day on the job, I asked the guy training me if we should card a bedroom door that was touching the carpet. Since then, I have never heard of problems involving doors touching the carpet. Has this ever been an issue?
I did that once too
Never did hear of a door bleeding into a carpet
No
Binghamton,New York
Only a couple over the years. Real old doors with mahogany finishes on them where they don't finish the bottoms, just raw drip stains.
Reactions: Brian H
Doug Cox
Delavan, WI
Doug Cox
I’ve never had a problem
sassyotto
Wisconsin
Paul
the distributor in Chicago called me back today and I placed an order. 3000 5x10 foil tabs for $120
Rather pay that than pay to replace a carpet. Plus it keeps me being a 2%r
Reactions: KevinD
